Questions on a 2006 dually
Old 06-09-2014 | 03:33 PM
motrapper's Avatar
Gentleman I found a 2006 Laramie Dually 6 speed manual with 123k miles
1 owner Truck ranch in southern Ut.
It has a K @ N air filter Not happy about that.
Tapped exhaust manifold but not hooked up to gauges
Raptor 150 fuel pump
Should I pull the intake to the turbo to view the Impeller to see if I can see any damage or what would be the best way to check if much dirt got by.
Raptor 150 would someone use this for just a better fuel pump??
Anything else to look for the Truck inside and out looks immaculate.
price 27k good bad or ugly??
Thanks
MO
Old 06-09-2014 | 04:45 PM
55_Cans's Avatar
Top of my head, other stuff to look at.
Front drive shaft - ujoints and diff seal.
Rear drive shaft - ujoints, steady bearing, diff seal and tranny seal.
Front axle trans ujoints, ball joints, and axle diff seals and fluid level.
Rear axle seals, fluid level.
Rear brake rotors - badly worn inside?
Front steering upgrade? Y-style original or T-style upgrade.
Trans cooler rad - wet up top?
Multifunction switch warranty to 150K km?
Cluster tach.
TIPM - Headlight, taillight issues.
Manual tranny bonus - auto has issues.
Fuel filtration, stock or upgraded?
Old 06-09-2014 | 05:25 PM
motrapper's Avatar
It is a Manual 6 speed
It just has stock fuel filters
What is the easiest test for the drive shafts
Thanks 55
sid
Old 06-10-2014 | 09:05 PM
Jeff in TD's Avatar
Check to see that climate control works well in all modes, too.
I have an 06 dually Laramie stick, and it's been a great truck. I don't think I'd give 27k for the one you describe, though. Maybe seller would be open to an offer.
jmccart
14
09-17-2007 08:23 PM
jrussell
17
09-17-2007 06:38 PM
Dragline
13
06-22-2007 05:03 PM
DanTana
03-06-2006 05:56 AM
Mcmopar
02-10-2006 08:25 PM
Quick Reply: Questions on a 2006 dually
