Question regarding BOOST values
Old 05-04-2005 | 10:50 AM
zog's Avatar
zog
I am always learning new "STUFF" about diesels...kinda exciting.
I installed my boost gaude yesterday and was afraid I had done something wrong. When I first started the truck, there was NO boost....I reved the engine, and still no boost. I rexhecked all hookups, connections, etc...but NO BOOST
Then I DROVE the truck and finally say teh boost gauge start to climb...once I put my foot into it I got up to 25 pounds, or so....neat to watch the boost gauge as the turbo spools up.
I was under the impression that there would be boost all of the time...but at 70 mph on level highway I am only running about 5 pounds...does this seem right????
Old 05-04-2005 | 10:54 AM
BigBlue's Avatar
Sounds perfectly normal to me. You'll only read boost when your putting a load on the engine. If I redline mine in park I can see maybe 2 lbs of boost but that varies from truck to truck.
Old 05-04-2005 | 01:25 PM
nickleinonen's Avatar
all is good there.... boost is load dependent, not engine speed dependent... you can give it full throttle while not moving to bring it to high idle [governed 3500rpm] and have next to no boost, but while driving give it wot at under 2000rpm and you can get nearly full boost...
the turbocharger is a thermal/pressure driven device... no heat/drive pressure, no boost...
Old 05-05-2005 | 12:21 AM
abryant's Avatar
Sounds just like mine, which is perfectly normal
Old 05-05-2005 | 09:55 AM
Nuttymopar's Avatar
Sounds normal but then again, don't you want MORE BOOST
Time to start bombing that truck
Old 05-05-2005 | 08:04 PM
Mark Thomas's Avatar
I was wondering how that worked, I kinda had the same question myself
Old 05-06-2005 | 09:38 PM
Badunit's Avatar
I know this comment was in jest but according to recent tests done for the TDR magazine, the stock turbo efficiency goes way way down above 24-25 pounds of boost. The intake air temp starts to skyrocket which is not what you want. Want more boost -- get a bigger turbo. Anyone bragging about more boost from a stock turbo is wasting their breath and courting a failure.
Old 05-09-2005 | 07:40 AM
Nuttymopar's Avatar
I agree. I had a PDR HX35 on my 1st gen and though I could hit 42 pounds of boost all day long and the EGT's didn't get super hot, I could feel that after 35 - 37 it just wasn't the same type of pulling power that it had around 27 - 35 or so. So though the numbers were still rising, I wasn't making power like it did when it was in it's sweet spot.
But then again, PDR's turbos are not stock turbos.
Bigger or twins would be the answer.
Old 05-09-2005 | 08:19 AM
Nuttymopar's Avatar
I can't wait to get gauges in my new truck. I don't dare do a thing until I can get a good baseline and then I start trying different things to get more power.
Old 05-09-2005 | 07:07 PM
underwoodtransp's Avatar
I am at the same conclusion.. I need gauges before I touch a thing!! I have had the dc computer ooked up to my truck trying to find the cause of some injector troubles and the tech told me when I was driving and he had it hooked up it showed 31lbs of boost he said that was pretty good and didn't say much more about it. I was wondering what the stocker was good for.
Old 05-09-2005 | 07:28 PM
Ramtough's Avatar
Same thing happened to me but i have learned enough not to panick right away. i goosed her and she moved a bit. but yeah not till there is a load on the engine. the highest i saw stock was 29-31 lbs on my 05. with the xzilliraider it will jump to 40 for a bit.
Old 05-09-2005 | 08:47 PM
zog's Avatar
zog
I agree....I still have to drill and tap for my EGT gauge, and after I get a base line, I hope to install a new exhaust system and intake kit....
corye
06-22-2009 08:56 PM
Cspotrun
12-05-2005 10:28 AM
vavtx
01-10-2005 09:37 PM
m1a convert
04-27-2004 08:27 AM
The_Warden
01-15-2003 06:14 PM
Quick Reply: Question regarding BOOST values
