Pyro Readings correct???
Sorry if this has been answered before, but the search function only turned up a bunch of 1rst and 2nd gen answers for this. I'm wondering what a normal idle temp (pre-turbo) should be around for a truck similar to mine. I'm showing like 160-170 at idle. I think it sounds too low as the 1rst and 2nd geners were saying 300 was normal for them. It seems to be accurate for cruising and when I'm hot roddin it around, I've gotten it up to the 1250 defuel limit I have my Bullydog set at. It seems to range from 600-850 for hwy cruising, is that normal? BTW I have my powerpup set at the performance level and the outlook is left at 100% all the time. Thanks!
I have never looked at my gauge during startup so don't know about the idle 160-170. The highway temperature sounds right @70 MPH I am just around 600* on level road & empty . Some hills temperature will get around 800. My definition of hills may be different from yours, I'm a flatlander. My truck is stock other than what is in my signature.
well I don't know then, my idle says way too low, but everything else seems to be the same as others. How far into the manifold are your pyro probes going? Like almost touching the other side? Or just sticking in a little bit? Or halfway?
Mine is pre - turbo. No power added yet.
Ghost Ram
14
05-28-2007 10:31 AM
greasefire
02-10-2006 11:31 PM
