Pump Running
Old 10-07-2010 | 05:59 PM
matcopage's Avatar
Pump Running
Just recently I keep hearing what sounds like a pump running in the egine compartment . . . I hear it when the truck is running and I am sitting in the cab . The dealership did the in tank replacement 2 years ago when my lift pump died . I have no clue what I will be checking for so any advice is appreciated .
Thoughts ?
Old 10-07-2010 | 09:44 PM
Highway 4x4's Avatar
They did remove the old filter mounted LP, didn't they?
Old 10-08-2010 | 10:25 AM
tryNto's Avatar
Does your Cruise Control work??
Old 10-08-2010 | 11:01 PM
thedan's Avatar
I had a leak in the vacuum hose under the hose on the firewall. It would hum/buzz. It would buzz for 9 seconds, then quiet for 5, then repeat. Check that out.
Old 10-09-2010 | 06:48 AM
Dodgezilla's Avatar
Yup. There is a vacuum pump behind the passenger side battery. It runs your cruise control and the lines are brittle and break easily. I was brushing my engine off one day and bumped into the "T" where it goes under the cowl and mine broke. I got some rubber vacuum hose and fixed it. I still hear the pump on occasion but nothing like when the line had initially broke...
Old 10-09-2010 | 12:02 PM
mq105's Avatar
Sure sounds like your vacuum pump. Best to find and fix the leak as soon as possible, before your pump burns up from running all the time.
Old 10-10-2010 | 05:59 PM
matcopage's Avatar
Thanks for the suggestions . . . I will look tomorrow and see . had dental surgery Friday that has kept me inside all weekend .
computermonkey
06-18-2012 09:24 AM
black&blue
02-18-2009 08:32 PM
BigBlue
08-28-2003 06:49 PM
BigBlue
24
08-28-2003 12:38 PM
TPilaske
16
11-22-2002 08:15 PM
Quick Reply: Pump Running
