PSI Advice for Toyo 285/75-17 ATs
Old 07-29-2009 | 08:30 AM
05HDRAM's Avatar
I put on these tires early this year, and they have been great so far. I am running 55 front 45 rear empty and they are wearing even. I have to tow a heavier load this weekend, and I know I should bump up at least the rear. I was thinking about 70, any advice ?
Old 07-29-2009 | 09:28 AM
wmonroe's Avatar
What does the sidewall say? Depending on how heavy the load I would probably run 70 in the rear and 60-65 in the front.
Will
Old 07-29-2009 | 10:47 AM
JJPage's Avatar
Mine are 285/75/18s, but I have been expermenting a bit.
Les Schwab recommended 60 psi all the way around, and that is where they aired them up to. That pressure seemed to handle my 5vr very well, but hit a bit hard on the rearend when empty. I now run 60 psi in the front and 50 psi in the rear while empty, tires all look very equally loaded. when I hook up to my trailer I will bump the rears back up to 60 psi.
Old 07-29-2009 | 11:00 AM
05HDRAM's Avatar
Will
80psi, but I didn't think I need to go that high.
Thanks. I think I will try 70, 10psi less than max.
Old 07-29-2009 | 12:05 PM
RiverRat2's Avatar
I run 50-55 on the rear empty and 65-70 loaded,,,, tires wearing fine
55 on the front
sidewall rating max is 80 psi
banana
04-15-2009 07:18 PM
FBs555CTD
15
03-17-2008 02:47 PM
msatow
09-17-2006 10:46 PM
Fummins
02-15-2005 08:31 AM
HOHN
11-02-2004 08:47 PM
Quick Reply: PSI Advice for Toyo 285/75-17 ATs
