Previous H.P. Increase??
Old 12-16-2006 | 09:41 AM
nooska's Avatar
Is there anyway to tell if a 3rd gen engine has been performanced enhanced after the chip etc has been removed from the truck...
Is there information stored in the trucks computer etc., wiring changes that could be detected etc????
Thanks
Old 12-17-2006 | 11:20 AM
RAMRODD's Avatar
Not sure if this will help but you can sometimes tell by looking at the exhaust manifold. If it looks a lot like new I think it is safe to assume that it never pulled hard. If it is crusty looking that probably means it had some hard pulling, or may have been power enhanced.
On my 04 the heat shield on the front of the manifold turned color. Also look on the manifold to see if their was a pyrometer. They may have taked it off and installed a plug.
Old 12-17-2006 | 06:39 PM
C Schomer's Avatar
Some leave tracks and some don't... so they say. The dealers can find the tracks. I hear some leave a time stamp at the last programming change. Craig
Old 12-18-2006 | 02:03 AM
ramtd02's Avatar
actually is the key cycles, with most programmers, they reset the key cycles everytime the re-program the ecm, the smarty saves these key cycles, hence why is is closer too being stealth. Problem is if the batteries have been replaced that too will reset key cycles.
Another way is too check for codes, most programmers leave a P0602 code in the ecm, and if the guy is un aware of this may not delete it before selling.
Old 01-27-2007 | 05:24 AM
chrigu's Avatar
the p0602 are normal with programmer? like smarty.
thanks
chris
Old 01-27-2007 | 11:38 AM
chrigu's Avatar
?? anybody answer?
Old 01-27-2007 | 01:13 PM
Smokeman's Avatar
Normal with Smarty
Old 01-27-2007 | 03:20 PM
ramtd02's Avatar
normal with all programmers, smarty is hit and miss, and i imagine all programmers are the same.
Old 01-27-2007 | 04:20 PM
wap's Avatar
wap
"Boxes" would be pretty hard to detect.
On the manifold theory, it is a good one but if the previous owner had an ofter market manifold and turbo(s) they could have just took the factory manifold off early on and replaced it with the new one. Then before they sell the truck but the original back on.
I would consider doin this, not to try and hide anything but just to recoup some of the cost of aftermarket parts, turbo, fuel pumps, manifolds (intake and exhaust), etc.
04ctd
05-24-2006 04:54 PM
Steve10
02-20-2004 09:40 AM
Rameister
08-12-2003 10:05 PM
Quick Reply: Previous H.P. Increase??
