popping sound in front
I have a popping sound under the floor board you can feel with your feet. It's not all the time just sometimes when you hit a bump and maybe turning. Seams like more on the passenger side. Any help?
I had noticed a very prominent knock in the floorboard of my truck after removing the track bar to install spring spacers. While the trackbar was out I also replaced the bushings in it with some NAPA parts for around $15 and re-installed. Started noticing the pop almost right away. Wasn't all the time but sometimes when I would turn a corner and/or hit a bump at the same time. Finally crawled under it 2 days ago and could have almost kicked my own tail-end...I was able to tighten both trackbar nuts/bolts almost 3 full revolutions . That extra bit seemed to firm up my steering a little and the pop is gone.
I agree with jhenson. Sounds like a body mount noise. Also if you have running boards that bolt up through the body mount check to make sure they arenot contacting the frame. Good luck.
Idaho Guy
16
02-12-2020 11:15 AM
Bobcat698
06-04-2006 08:21 AM
MoparRiggan
02-10-2006 07:44 PM
guidster
06-06-2005 11:16 AM
