PO243 code
Old 08-21-2005 | 11:04 PM
jk1364's Avatar
PO243 code
Can you tell me what this code is PO243. Do not see this on the list.
John
Old 08-22-2005 | 08:48 AM
displacedtexan's Avatar
Turbocharger wastegate solenoid A malfunction...
Not sure beyond that but that is what the repair manual says...
Old 08-22-2005 | 12:24 PM
jk1364's Avatar
Thanks.
John
Old 08-22-2005 | 10:32 PM
Glad to help...
What were the symptoms of the solenoid malfunction?
Old 08-23-2005 | 09:49 AM
bigblock2stroke's Avatar
low boost?
Old 08-14-2007 | 02:11 PM
Chubby's Avatar
Just had the same thing on My 04 set a code, on mine the wastegate will stick open. I noticed it when shifting under a load.
Old 08-14-2007 | 09:11 PM
iaddiesel's Avatar
I just had the same thing along with Po480 Fan Clutch They both share the same fuse on my 06. It lives under the hood in that fuse box on hte drivers side, I believe it is number 6 as far as location in the box.
Old 08-15-2007 | 12:24 AM
moparmatt's Avatar
ive also had this code i believe its and 04.5 thing..the wires to the wastegate crack..it can be spliced/sauterd back together i used electrical tape and to red wire connectors, i tried buying the new solinoid but was told it was on back order that was about 5 months ago and i still havent been told that it has came in.... https://www.dieseltruckresource.com/...highlight=mojo
Old 08-15-2007 | 05:07 PM
johndeere01's Avatar
had the same problem only my wastegate was rusted shut so i got a new turbo under warrantee
hylander
03-20-2009 09:35 PM
coope3
02-21-2009 04:49 PM
O.T
09-06-2007 06:10 PM
Terraizer
12-14-2005 03:56 PM
CTD NUT
04-05-2005 04:45 PM
Quick Reply: PO243 code
