please help... 2004 dodge ram runs for 5 min then dies
i have tryed everything i can think off.. i have a 2004 dodge ram and after replacing the tranny it will only run for 5 min then it shuts its self off.. cycle the key off for 5 sec then back on and the truck will fire agian..
thanks nate
thanks nate
Check for codes. Do this by cycling the key to off then on 3 times. Look in the mileage window and read the codes that it shows or DONE which means you have none. Post the codes on here.
http://wiki.dieseltruckresource.com/wiki/Computer_codes
P2509 Ecm/pcm Power Input Signal Intermittent
P0088 Fuel Rail Pressure Signal Is Above Max Limit
P0882 Trans 12 Volt Supply Relay Control Circuit Too Low
Those are the codes. Hopefully somebody can help you work through the problem (s).
badme
32
09-30-2019 11:49 AM
vintovka
04-30-2012 12:38 PM
Luckyrogue
01-16-2008 11:54 AM
xfeastonarsex
02-05-2007 05:35 PM
