Plastic clips holding transmission lines
Old 03-30-2013 | 02:44 PM
jon05ctd's Avatar
Exclamation Plastic clips holding transmission lines
I need to replace the upper transmission line from the cooler to the front oil cooler.
2005 CTD
I see there are two clamps holding the lines together. I got the forward clamp off but can not figure out how to remove or unclip the clamp near the block.
HOW does this come apart?
Old 03-30-2013 | 07:39 PM
wiskeyVI's Avatar
I dread messing with those. I wish I could help.
Old 04-01-2013 | 05:48 PM
Classy5.9's Avatar
They are almost like a barbed fitting. You need a tool that slides into the connector to flare the tabs open and then you can separate the lines.
Old 04-02-2013 | 09:16 PM
wiskeyVI's Avatar
May be able to get the tool at harbor freight?!
josterbauer
02-24-2010 06:55 AM
Moobesor
27
03-12-2008 12:56 AM
rmk4x4
03-19-2007 10:01 PM
9512vCTD
02-18-2007 12:34 PM
simonswb6
09-16-2004 12:37 AM
Quick Reply: Plastic clips holding transmission lines
