pitman arm rattling
Old 01-06-2009 | 02:17 PM
reaves11's Avatar
pitman arm rattling
I noticed the pitman arm has some play and the steering box shaft has play when I was under the front end. Would the steering box brace with a steady bearing fix this trouble? I heard Solid Steel Manufacturing in Weyburn makes these braces or front ends.
thx for any info
Old 01-06-2009 | 02:55 PM
bradler's Avatar
Sector shaft play in the gear boxes seems like a common problem, especially with bigger tires. It can cause slop in the steering. And if the sector shaft isn't too beat up, the gear box brace works. I caught mine early and put the brace on before it got too bad, cheaper than a new steering gear and mine is still rocking nice and tight. Plus the entire front end feels stiffer/tighter.
The pitman arm mount to sector shaft should not be rattling though, or else its loose = major danger. The pitman tie rod end could have some play? Maybe your sway bar end links are rattling?
Old 01-06-2009 | 02:58 PM
bradler's Avatar
I have the Solid Steel brace but this one from Defiant is very nice also and cheaper...
Old 01-07-2009 | 12:34 AM
Fern's Avatar
Never seen that one before. Looks very clean.
Old 01-07-2009 | 06:40 AM
stroker101's Avatar
i like the brace from Defiant. there will most likely be one bolted to my truck next month.
Old 01-07-2009 | 07:32 AM
djbikeman's Avatar
If everything else is OK, their is an adjustment for excessive sector shaft play on top of the shaft. requires an Allen wrench and open end wrench to do.
The brace is also a great mod to do as well, but I think you still need to address the play issues.
Old 01-07-2009 | 08:08 AM
stroker101's Avatar
no issue's with mine right now. just installing one to prolong the integrity of all components associated with adding the brace
exsanguinate
12-14-2009 04:13 PM
BigDan
07-08-2006 11:04 PM
BigBlue
09-21-2004 09:44 PM
BigBlue
09-18-2004 02:13 AM
royalnine
07-18-2004 08:56 PM
Quick Reply: pitman arm rattling
