P0341 Code-camshaft position sensor??
Old 10-16-2011, 11:15 AM
CoastalDav's Avatar
Originally Posted by Brad5502
Have had good starts for two days since replacing the Crank sensor. Taking the 5th wheel out today. Hoping problem is solved!
Did the CPS fix your problem?
For the last month or so, I've noticed want I feel, was an engine miss when the engine is cold. No codes. After it's up to operating temp, it ran fine. Early last week, I was at Walmart at Hartwell, GA. Started the truck, exhaust brake was on since I used it coming across from I-85. Engine temp was above 175 and it should not have come on. Turned it off and left headed back to Fair Play, GA.
Left a stop light, felt a stumple and got a code. P0336 Crankshaft Pos Sensor.
Cleared the code, it did not come back. Truck ran fine.
This past Friday while leaving Cleveland Ga, again cold engine, got a stumple and the CPS Code. Cleared it twice and it came back each time. Drove it back to the Camp Ground, with engine light on, engine ran fine.
Strange thing, the exhaust brake did not work while driving back. Indicator light was on meaning the brake was on.
Next morning, I cleared the code and the exhaust brake worked.
Anyone know how the CPS affects the exhaust brake?
Another funny thing, after I installed the exhaust brake on my 2000 dodge
the CPS failed 10,000 miles after installation. I just had the EB installed last July. Engine has about 8000 miles on it since the EB was installed.
Is this just a freak or is there a relationship between the two?
Anyone else had this happen?
Thanks in Advance.
Dave
Old 10-17-2011, 11:16 PM
alboy's Avatar
I had trouble with the cam shaft sensor last year heading to Palm SPrings,they replaced sensor ran good for a week or so than threw the cs code again,turned out to be the connector where it runs thru the condensor had almost broke off. SOLDERED THEM UP END OF PROBLEM
Old 06-29-2014, 08:03 PM
builtnotbought1's Avatar
I am having the same problem with a lot of hiccup while driving?
andre3k
05-27-2014 10:56 PM
Totallyrad
17
09-28-2013 04:23 PM
hellwig333
08-23-2006 09:24 PM
SmokenRam
05-16-2006 09:00 PM
SilverRam01
18
11-28-2005 11:54 PM
Quick Reply: P0341 Code-camshaft position sensor??
