p0243 p480 codes
Old 12-10-2010 | 11:54 PM
PSURPRENANT's Avatar
p0243 p480 codes
07 2500 4x4...25,000 miles.. after installing the power cord for the block heater and running the truck for about 30 minutes these codes came on. In addition i have installed a snow plow mount....anyone had similar problems?
Old 12-11-2010 | 08:31 AM
ColdCase's Avatar
Check for a blown fuse, #6 I believe.
Old 12-11-2010 | 09:11 PM
thanks will check first thing in the am
Old 12-12-2010 | 06:53 PM
By the time i got to the garage today, the light had gone out......the fuse was in fact good.....the turbo solinoid was connected properly and had not been disturbed.......the only thing i found was i had forgotten to connect the fog lights......since the mil was out, not sure what the cause was......will keep an eye on it.......
Old 01-04-2011 | 09:47 PM
Well since i posted last message, the codes have returned twice since this last posting.......has anyone heard of this problem as a result of installing the block heater power cord? Could this be a software problem that an upgrade will solve?
Old 01-10-2011 | 09:43 PM
RADICALRAY's Avatar
make sure the map is pluged in its on the same side as the heater plug..maybee bumped it its on the air intake tube
Old 01-11-2011 | 08:44 AM
cbrahs's Avatar
block heater has nothing to do with any circuit in the system. its a stand alone system. you may have left something unplugged during the installation of the power cord but it isn't the block heater at all.
p0243
Case Number K46965697
Vehicle Issue MIL. P0243. Low power.;No other fault codes are logged. Inspect the Wastegate Control Valve (actuator) wires for chafing against the battery ground cable. The insulation on the wire(s) may have rubbed through allowing the copper to corrode. In some cases the wire may have broken off at the actuator.
System or Component Lack of Power / Sluggish;DTC / Error Message;Turbocharger,Group 18 - Vehicle Performance / Driveability
Recommendation Replace the Wastegate Control Valve.
Modification Date 01/05/07 1:40 PM
p0480
this is a fan issue here are the possibilities
Possible Causes
(K160) FAN CLUTCH CONTROL CIRCUIT OPEN
(K160) FAN CLUTCH CONTROL CIRCUIT SHORTED TO THE (K690) SENSOR GROUND CIRCUIT
(K160) FAN CLUTCH CONTROL CIRCUIT SHORTED TO BATTERY NEGATIVE
RADIATOR FAN
ENGINE CONTROL MODULE (ECM)
Old 01-11-2011 | 08:40 PM
Thanks to radicalray and cbrahs for your replys......i agree that the block heater is a separate circuit.....i will check for the map sensor wiring and make sure its connected......in addition i will look again at any connections in the area of the block heater. thanks again
Kman9090
11-07-2010 07:05 AM
polk5295
10-12-2010 02:56 PM
sCreamin400
10-26-2008 02:50 PM
upjeeper
01-26-2008 09:36 AM
tristan21
0
06-12-2006 03:00 PM
Quick Reply: p0243 p480 codes
