P0148 code on '06 and weird idle
my 06 idles fine for a few seconds then chokes down and almost dies, then picks back up and runs fine for a few more seconds till it does it again, put in a new lift pump and fresh filter, didnt help, runs fine at any rpm above idle, scared to drive it dont want to mess it up worse, havent taken it to the dealer because our dealer here sucks, turned my edge juice to stock and its showing the p0148 fuel delivery error code, any suggestions i should try?, thanks..
Pulled from the 06 service manual:
P0148-HIGH PRESSURE COMMON RAIL (HPCR) CHECKSUM
For a complete wiring diagram Refer to Section 8W.
² When Monitored:
While the engine is running.
² Set Condition:
A deviation between the fuel pressure set point and the actual fuel pressure.
Possible Causes
OTHERS DTC’S PRESENT
FUEL LEAKS
FUEL CONTROL ACTUATOR
FUEL PRESSURE SENSOR
CASCADE OVERFLOW VALVE
CHECK VALVE DAMAGED OR BLOCKED
FUEL RETURN LINES OBSTRUCTION, DAMAGE, OR DEBRIS
LIFT PUMP FLOW
AIR IN FUEL SYSTEM
LEAKING FUEL INJECTORS OR HIGH PRESSURE CONNECTORS
PRESSURE LIMITING VALVE
HIGH PRESSURE FUEL PUMP
INTERMITTENT CONDITION
² When Monitored:
² Set Condition:
Possible Causes
FUEL LEAKS
LIFT PUMP FLOW
AIR IN FUEL SYSTEM
DixieMfg,
I have the same issue on my 2004.5 - it is like it hick ups while idling.
I have 170K on the truck - i was thinking maybe it is bad injectors. You are correct in that it runs just fine above idle - I continue to drive mine. Let me know what you find out.
Scott
Scott
scoutman
53
09-03-2014 10:36 AM
Batts
13
06-02-2006 02:35 PM
StealthRam
09-21-2005 02:27 PM
