P0113 Intake Sensor High
Hello,
Can someone please tell me what this code really means and what I should do to fix it? From what I have read, it looks like my air temperature in my intake is reaching unsafe levels? It must be a defective sensor though since I can clear the codes at night and then start the truck in the morning and I get the trouble code within 60 seconds.
Here's the specs on my vehicle:
2005 Dodge Cummins 3/4 ton CrewCab 4x4
Stock wheels and tires
Manual tranny
MAGNAFLOW 5" exhaust
Power Pup programmer
Bully Dog Outlook Monitor
K&N Stock Replacement Air Filter
I have only been running the programmer in the tow mode and I don't really drive my truck hard except for if there is a need to pass a slow driver or occassionally when my son says "Go Daddy". Any advice/help is greatly appreciated.
Also, I called the Dodge dealer and they said they don't show an "intake sensor", but they show a bunch of other sensors. IF replacement is recommended, any help with the technical part name is appreciated too.
Manual tranny
I looked for an update, but BullyDog only had one for the Duramax and the Powerstroke. I took my truck back to stock and still got the codes. Then I removed the outlook monitor and never had an issue again.
adamsmarshall
09-14-2008 01:18 PM
