Owning an 03 and wondering when.......
Although it only has 60K miles, mine is proving itself as a big blue towing machine. Its been vastly superior to my previous vehicle, a 1999 4Runner.
Cracked alternator bracket.
Reverse light switch.
Taillight circuit boards.
I did the fuel tank vent mod where the vents get hoses and a filter so dirt doesn't get into the tank. It needs shocks and u-joints. I probably should check ball joints soon. I have the random 'Check Gauges' blink which is documented in a TSB, but I don't care to have it reflashed for fear of what else they might program into it.
The only thing I have HAD to do to my 04 truck (other than oil and filter changes and tires) was replace front brake pads at 120k. Everything else has been by choice and since it turned over 100k. Not a single glitch...
Love my '03. Great mileage and now it's paid for. However, I have had a few repairs:
reverse switch
ball joints (upper/lower)
front left wheel bearing
front differential rebuild
lift pump
real pinion seal
water pump
front axle u-joints
drive-shaft replaced
all drive u-joints
I have a diesel smell from the engine now. Probably a leaking cp3 or fuel rail.
Overall I am still happy with the '03.
reverse switch
lift pump
real pinion seal
water pump
front axle u-joints
all drive u-joints
I love mine but I have had to replace the transfer case twice. Other than that just a cracked dash which Chrysler has agreed to repair.
I am hoping that it will last another 10 years.
No mods just bone stock.
Riddle Family.How about a little more info about your truck.Your sig.like the rest of us have.H.P./color,mods,tires/wheels if not stock,trans etc. Also more info on why TWO transfer cases,cause,mileage etc.
i have an 04.5- the only issues i have had is ball joints and u- joints- so i replaced the whole entire front end, including installing lock out hubs. other than that in 83,000 miles- truck has been trouble free!
Both of the them were replaced by Dodge without question. Now this third I keep a real eye on. I check the fluid about once a month or more.
I've had a few isseus with my '03, but nothing I consider major: HVAC mode door took a crap TWICE and I've had both front axle joints, 1 u-joint in the front drive shaft and 2 in the rear shaft and the driver's side upper ball joint. I've replaced ALL the u-joints with Federal-Mogual Premium GREASABLE joints and plan on throwing in a free-spin hub kit before the unti bearings konk-out. Other than that, it has more power than I really need, gets fuel mileage as good or better than some cars, and it runs every time I twist the key (knock on wood). Over all I'm quite happy with my '03.
The first at 50000, the second at 65000.
Like I said Dodge covered both. Right now I have 71000. Check it all the time now. Too worried that I will have to replace it again out of warranty. I am sure I could argue about it with them.
They completely replaced both ot them with a new or rebuilt, don't know which one. But it wasn't the original I know that for sure because I saw them laying on the ground when I went to pick the truck up.
