oversized banjo bolts?
is there any oversized banjo bolts for the fuel canister or can you just pull it out and drill them? thanks i am ordering the one from genos and the 2 washers and a fp gauge thanks
if u ordered them allready the question kinda pointless but u can drill yours out, ive allways just replaced them with jic fittings from vulcan performance. the thread is 12mm 1.5, imho the best way to go, u can R & R fuel lines without ever having to worry about new sealing washers.
When you have it apart, take a look at the fitting the hose connects to. This is a big restriction area also. I agree with mini14, replace them with JIC fittings or AN fittings with push lock connectors.
i have drilled the one out on my first gen when i installed the new lift pump. it is kinda a pita to drill brass but we'll make it work! and then you can chamfer if with a larger drill bit by just pushing on the banjo bolt (pretty hard) and then rotate the drill bit in your hand!
Would this work instead? http://www.genosgarage.com/prodinfo.asp?number=LT_FFCPP A fuel filter cap tapped for a pressure port.
The fuel filter cap gives you a place to put a gauge. This really does not address the input and output restrictions. The banjo bolts and the adapter piece they go thru are where the restrictions are.
