Oil pressure variation in '03
I was wondering about my oil pressure. I just bought a ’03 2500 CTD 4x4 with 24,500 miles and my oil pressure is always within the operating range. When cold it is always at the high mark but when hot it moves from just inside the high mark to about 1/8th of in inch inside the low as engine rpm changes from driving to ideling, and I was wondering if this is normal because some vehicles I have had always show almost the same pressure at idle and off idle when hot. I ask because a friend made comment that is CTD always shows high oil pressure. I don’t know if a very low viscosity oil was used at the last oil change or not, it was done by the dealer when they took the truck on a trade in. Also since I don’t know when the fuel filter was changed is it a good idea to go ahead and change it?
Thanks
Jeff
Thanks
Jeff
From: Dayton, NJ (temporarily while In USCG on Staten Island)
I have a mechanical in the cab from the filter housing. When stone cold it idles at 82psi, when warm and cruising down the turn pike, it is about 68psi and the engine temp is 189. The idiot gauge in dash at cruising is a bit above 40. so your probably running about 60-65psi if the stock gauge is in the so called good range.
Haynsling
04-18-2012 07:36 PM
GlennRMK
05-24-2007 10:46 PM
Vontin111
16
12-11-2005 04:36 PM
