Oil Lines...
Old 03-28-2003 | 09:34 PM
RHC's Avatar
RHC
Oil Lines...
Question #1: Which way is oil flowing through my turbo, up the black line into bottom side of turbo and out the silver braided hose and into the oil filter or the other way?<br><br>Question #2:<br> Which way does the trans fluid flow, to the cooler<br> in frount of the raidator and back through the small<br> cooler at the back of the block and then back to <br> the trans or the other way?<br><br>Question #3:<br> Is that engine oil lines that connect to the cooler at the back of the engine, the same ones that the transmission lines go to?<br><br>finally got a chance to crawl under my truck and look it over.<br> <br> thanks for replys <br><br>
Old 03-29-2003 | 12:43 AM
westcoaster's Avatar
Re:Oil Lines...
The silver braided line into the turbo is the high pressure feed, black line out the bottom of the turbo is the return line to the crank case. silver=in, black=out<br>I can't speak to the other two you asked about...
Old 03-29-2003 | 08:43 AM
Shovelhead's Avatar
Administrator / Scooter Bum
Re:Oil Lines...
The hot Tranny fluid goes from the tranny to the small heat exchanger at the right rear of the block first, then to the radiator. <br>That line is the best place to monitor tranny temps, it's the hottest fluid in the system.
Old 03-31-2003 | 04:30 PM
RHC's Avatar
RHC
Re:Oil Lines...
Commando, sorry bud, but it was Red.<br><br>Shovelhead, Where do you route the wires from a temp. sensor into the cab? Thinking of mointoring my turbo oil temp and trans oil temp.<br>
Old 03-31-2003 | 04:33 PM
Shovelhead's Avatar
Re:Oil Lines...
All my wires/lines come in through the large grommet beside the brake booster.<br>The &quot;3 pedal&quot; guys have the clutch linkage going through it.
Greguw
30
12-04-2005 09:00 PM
jazz_kt
07-08-2005 11:17 PM
MrKen
02-25-2005 04:22 AM
hellotbone
09-01-2003 08:46 PM
Quick Reply: Oil Lines...
