oil filters
Old 06-05-2014 | 09:32 PM
merv1's Avatar
oil filters
what oil filter is best for my dodge diesel
Old 06-05-2014 | 10:24 PM
rockcrawler304's Avatar
Here we go again!
If you search you will have days worth of reading the debates here! However many recommend the Fleetguard Strata pore filter. (that is what I run) Baldwin is also a top filter. The one thing that MOST (but not all) will agree on is DO NOT run a Fram on these engines.
You can buy the Fleetguard filters from Genos Garage here http://www.genosgarage.com/FLEETGUAR.../#.U5E0BSiCdh4 I also run the Fleetguard fuel filters from Genos.
Old 06-06-2014 | 06:51 AM
MikeyB's Avatar
Stick with Wix, Fleetguard, Baldwin, Donaldson. Will never go wrong with any of those.
For the fuel filter use Baldwin PF7977 in the canister. It's the best drop in available.
Old 06-06-2014 | 10:29 AM
Fiftygrit's Avatar
Like Mikey said, all I have ever used.
Old 06-06-2014 | 01:13 PM
AH64ID's Avatar
The Donaldson ELF7349 is the best filter you can get, here are the specs on the rest.
Donaldson P558615 40um @ 98.7%, 20um @ 50% Cellulose
Fleetguard LF3972 30um @ 95% (35um @ 98.7% last info) Cellulose
Wix 57620 30um @ 95%, 20um @ 50% Cellulose
Wix 57620XE 25um @ 95%, 14um @ 50% Glass Enhanced Cellulose
Baldwin BT7349 30um @ 98.7%, 12um @ 50% Synthetic blend
Fleetguard LF16035 30um @ 100% (25um @ 98.7% last info) Stratapore Synthetic
Purolator L45335 20um @ 97.5% Cellulose
Purolator PL45335 20um @ 99.9% Synthetic
Amsoil EaO80 20um @ 100%, 15um @ 98.7%, 7um @ 59.97% Nanofiber Synthetic
Donaldson ELF7349 20um @ 100%, 15um @ 98.7%, 7um @ 59.97% Nanofiber Synthetic
Mobil 1 M1403 10um @ 50% Synthetic blend
Old 06-06-2014 | 02:40 PM
jadocs's Avatar
Is there anything wrong with the stock MOPAR filter? I can get those for about $7, or are the ones listed above "better"?
Old 06-06-2014 | 02:45 PM
AH64ID's Avatar
The Donaldson P558615 is the only filter that isn't better or equal to the OEM filter.
Old 06-06-2014 | 03:48 PM
jadocs's Avatar
Thanks, which ones are better? Or is everything minus the Donaldson just equal?
Old 06-06-2014 | 03:54 PM
AH64ID's Avatar
The smaller the micron with the higher the rating the better. Donaldson. ELF 7349 is the best, P558615 is the worst.. In that list.
Old 06-06-2014 | 04:15 PM
jadocs's Avatar
Got it thanks. I wonder what the micron rating on OEM is? I need to make a decision whether to stick to my $7 MOPARs or go with the ELF 7349.
Old 06-06-2014 | 04:33 PM
merv1's Avatar
oil filters
thanks to all i will go with fleetguard from Geno's
Old 06-06-2014 | 05:00 PM
AH64ID's Avatar
Www.filterspro.com has the ELF7349 at a price that makes it very worthwhile.
If you want to run the standard Fleetguard you may as well buy the Mopar from Walmart, it's a good chance it's the same filter.
DodgeCowboy
07-23-2008 10:12 PM
bcfitzsimons
06-26-2008 12:17 PM
staarma
28
05-01-2008 11:10 AM
fitzydog
10-12-2007 10:23 AM
kelley15
08-20-2007 04:52 PM
Quick Reply: oil filters
