Oil change issues
Old 10-10-2013 | 09:07 PM
michael/edge's Avatar
Was it hot when you changed it?
I notice mine will leak a little out depending on the temp of the oil.
I mostly only make a mess when im in a hurry!!!!!!!!!!!!!!!!!!!
Old 10-05-2014 | 08:38 PM
RamDodgeSam's Avatar
trying to keep this question in an appropriate thread instead of a new one and found thread this while searching for the answer to my question ...
I changed the oil in the ram today. I didn't prefill the new filter before installing it. In retrospect I wish maybe I had. I've only idled it since then to circulate new oil and then check levels. Maybe 20 seconds or so. Would that be enough to fill it? I watched the pressure, and it never dipped to zero briefly like it does on my old mercedes diesel after a change.
Another question, I feel like an idiot but I can't tell for sure from the dipstick what level its at. Never had trouble on my 12 valve. Oil seems to be smeared all over the dipstick. At worst, I overfilled it slightly. Maybe the filter isn't full yet. I'll check it in the morning again.
Old 10-06-2014 | 12:43 AM
Spooler's Avatar
Need to let it idle more than 20sec. Let it idle for at least a minute or 2, wait 15 min and then check. The oil pressure gauge is fake, nothing more than an idiot light. It will only let you know when you have less than 5psi of pressure or so.The output displayed on the dash is pre-programmed into the ECM.
Old 10-06-2014 | 02:01 PM
So the oil pressure gauge is just tied to rpm or something? Is there a real gauge that would fit in the dash in that space I wonder?
Old 10-06-2014 | 10:31 PM
Spooler's Avatar
Do a search on here. Someone has done it before.
jmccart
13
05-27-2009 09:45 PM
gsqhtr
07-02-2008 12:48 AM
doitl8r
06-04-2004 11:14 AM
snice
14
04-29-2003 08:41 PM
Quick Reply: Oil change issues
