Oil Change
From: Shreveport LA for 10 days at a time, Groveton TX the rest
Oil Change
At what mileage did you guys change out the original oil in the motor? I have roughly 5000 miles and think I am going to change it at 6000. After that I'm going to go 7500 miles between changes like I have on every other Cummins that I've had. Thanks in advance.
First one was around 4,500 and I let the dealer do it - from what I have read it was a good decision. Oil filter is a pain sometimes the first change. My second I did roughly 7,500 later and my oil analysis came back saying I should try and extend to 8,500 - 9,000 before my next change.
7,000 then 15,000 then 23,000 and every 9,000 since. I only tow with it 20% of the time. I don't leave it idling needlessly and I don't have it hopped up. I had sampling done each of the original times.
Chris
Chris
I changed my oil at about the same when I first bought the truck- I also agree with the 5000 even with CI4+ oils. At least for me it has proven to be a good interval number.
same for me first at 500, then 7500 there after ward. any one else notice how BLACK the oil is now on the 3rd gens, my 99 was like a gas motor on oil changes even at 7500 you could read the dipstick through the oil, now on mine RIGHT after you change it your lucky to read it though the oil and theres no way after a couple of days, any one an explination of this?
I changed mine at 1050 mile as I found out 2 weeks after I bought it that the oil had been in it for almost 9 months. I think everyone should check to see how old the oil is not just the amount of miles on it.
I just changed my oil again as it had 7K on it and Dodge said that the oil has to be changed every 6 months or 7500 miles, mine had been in for over 7 months. I was told even though it was synthetic it had to be changed out at 7500 miles as over the summer we had temps over 90 degrees and that means it was operated under sever conditions.
I did a UOA because I wanted to know for sure how well the oil was doing. The dealership even said all engines are operated under sever conditions as listed in the owners manual. Well when the UOA came back I found out that I still had a TBN of 10.03, so I had thrown out darn good oil because of what I was told by Dodge.
I think everyone should be doing UOA to see how well there oil hold up and how long it will last so as to not be throwing out good oil and wasting their hard earned $$$. If you do an UOA there is no more guessing of how well your oil is holding up.
My $0.02
My $0.02
