Odd piece attached to fuel filter
Old 09-12-2010 | 03:07 PM
509Diesel's Avatar
Hi guys,
I just purchased this truck about a month ago, I went to change the fuel filter yesterday and it looked a bit different than what I have seen in manuals and write ups. I was wondering if anyone could give me some information on why this unit is different on the top. I attached a picture for you to see, but I didn't have ladder with me so it is at sort of a bad angle. It seems to be tapped in on the top of the cap.
I've been doing some reading about a socket that everyone seems to use, but with this additional valve thing on the top that probably won't work. I assume a end wrench of some sort would make it work? I do see the nut that is supposed to be removed under this piece, whatever it may be.
Thanks in advance.
Old 09-12-2010 | 03:38 PM
JHardwick's Avatar
That looks like the cap from Genos that has been tapped for a fuel pressure sender.
Old 09-12-2010 | 04:04 PM
White Ghost's Avatar
fuel pressure sending unit.nothing to wrry about
Old 09-12-2010 | 04:34 PM
Dodgezilla's Avatar
Yup, I have the same thing on mine.
Old 09-12-2010 | 07:54 PM
1-2-3's Avatar
Just a plain ole guy
Do you have a Fuel Pressure gauge? If so, that's a good thing.
Old 09-13-2010 | 12:17 AM
509Diesel's Avatar
Thanks for the quick replies folks. I do not have a fuel pressure gauge in the truck at the moment. Maybe there was one in there before, the previous owner left the EGT, Boot and trans gauges.
Thanks once again.
Old 09-13-2010 | 11:25 AM
BMH95's Avatar
It could just be a pressure switch to a little LED. That's what I had in my truck until it started leaking...
Old 09-13-2010 | 12:46 PM
AggieJustin's Avatar
The tag on the side shows that to be a 16psi fuel pressure sender. You can trace the wires to see where they go. The PO may have had a fuel pressure gauge as well, but removed it for some reason.
One other piece of advice on the fuel pressure gauge. It would be best if you remote mounted that sender instead of having it threaded into the fuel filter directly. If you remote mount the sender and connect it to the filter housing with a length of rubber hose, it helps isolate the sender from the vibrations it experiences right now being directly mounted to the engine. Plus, the rubber hose helps dampen any pulses from the injection pump.
Old 09-13-2010 | 09:42 PM
509Diesel's Avatar
Thanks Aggie. You folks are all very helpful. :-)
Old 09-14-2010 | 11:11 AM
Bankdude's Avatar
I used a grease gun extension hose. Available almost anywhere, already threaded and works great to isolate the pulses.
Old 09-14-2010 | 12:10 PM
AH64ID's Avatar
Odd that its a 16psi switch, if the LP is stock it will never see 16psi.
Old 09-14-2010 | 02:35 PM
I'm betting it is a pressure sender, not just a pressure switch. It looks exactly like my Westach 16psi sender (as well as my 30psi sender).
Old 09-14-2010 | 02:36 PM
AH64ID's Avatar
Very true.
Old 09-14-2010 | 06:44 PM
Dodgezilla's Avatar
That isolator is a good idea too. I'm on my second sender and it was acting weird for about a week here recently but finally is back to normal. I still haven't learned my lesson and gotten the isolator kit yet.....
Old 09-15-2010 | 02:44 PM
BMH95's Avatar
Does it have an aftermarket pump under there somewhere?
samiam4
09-26-2010 06:04 PM
GSP
09-24-2008 03:52 PM
Death Dealer
02-22-2008 03:58 PM
Pa outlaw
10-21-2004 07:35 AM
AKDSLDOG
03-14-2003 05:53 PM
Quick Reply: Odd piece attached to fuel filter
