Now I'm confused. Need some axle help ??
It's time to change the axle fluid and I need some help to determine just how much. I checked the Amsoil site and they make it even more confusing. I have an '06 3500 4x4. They list 10.5" AA & AA EL at 5.3pts fluid. They also list 11.5" AA open at 8.9 pts. & 11.5" AA Tri Ri at 8.5 pts. fluid. The easy part is that they all take the same fluid ( minus the additive in some). How can I tell what I have or do I just have to purchase enough fluid for the biggest one??? It only lists a 9.5" for the front at 5pts. The owners manual isn't much help except that it tells me that the 2500 / 3500's do not get any limited slip additive.
So I would appreciate some help here if anyone has solved this mystery. Not sure yet if I'll go with the Amsoil here but thinking about it.
Thanks to all the Dodge Heads out there.
DESCRIPTION SPECIFICATION
AUTOMATIC TRANSMISSION
Service Fill - 48RE 3.8 L (4.0 qts.)
O-haul - 48RE 14-16L (29-33 pts.) L
Service Fill - 45RFE/
545RFE
4X2 - 5.2 L (11.0 pts.)
4X4 - 6.2 L (13.0 pts.)
O-haul - 45RFE/545RFE 14-16 L (29-33 pts.) L
L Dry fill capacity Depending on type and size of
internal cooler, length and inside diameter of cooler
lines, or use of an auxiliary cooler, these figures may
vary. (Refer to 21 - TRANSMISSION/AUTOMATIC/
FLUID - STANDARD PROCEDURE)
MANUAL TRANSMISSION
NV3500 4X2 2.27 L (4.8 pts.)
NV3500 4X4 1.99 L (4.2 pts.)
NV4500 3.79 L (8.0 pts.)
NV5600 4.50 L (9.5 pts.)
TRANSFER CASE
NV241 GENII 1.6 L (3.4 pts.)
NV243 1.6 L (3.4 pts.)
NV244 GENII 1.6 L (3.4 pts.)
NV271 1.89 L (4.0 pts.)
NV273 1.89 L (4.0 pts.)
FRONT AXLE ± .03 L (1 oz)
C205F 1.66 L (3.5 pts.)
9 1/4 AA 2.25 L (4.75 pts.)
REAR AXLE ± .03 L (1 oz)
9 1/4 2.32 L (4.9 pts.)***
10 1/2 AA 2.25 L (4.75 pts.)
11 1/2 AA 3.62 L (7.65 pts)
*** With Trac-Lok add 118 ml (4 oz.) of Limited Slip
Additive.
** Includes 0.9L (1.0 qts.) for coolant reservoir.
*Nominal refill capacities are shown. A variation may
be observed from vehicle to vehicle due to
manufacturing tolerance and refill procedure
From my 04 repair manual.. Same axles.. Diesel has 11.5 rear and 9.25 front
I fill it until it comes out. the stock cover. Was told fill level is 1/4 below +/- 1/4 inch so I fill it until it comes out the fill hole. Has worked for the 1st 160k
545RFE
MANUAL TRANSMISSION
TRANSFER CASE
Additive.
Chuck K.
14
06-24-2009 07:42 AM
sledneck1
02-18-2007 05:00 PM
