"normal" oil usage?
Old 08-27-2006 | 12:38 AM
pybyr's Avatar
"normal" oil usage?
What's considered "normal" oil usage for an '06 Cummins 325/ 610? Vehicles/ engines that I have owned over the years have run the gamut from Toyotas that never showed _any_ detectible usage to Fords whose engines worked very well but went through at least a quart every 1000 miles even when "young" and where the usage was (supposedly) an intentional feature of the design (to keep rings and top end well lubed, or so the story went). Thanks!
Old 08-27-2006 | 01:42 AM
Smkndzl's Avatar
Normal is anything below .07 oz. per hour.
Old 08-27-2006 | 04:31 AM
TexasCTD's Avatar
I have never been able to detect ANY oil usage on my truck. The dip stick is just as full when I drain it as 5000 miles earlier when I added it.
Old 08-27-2006 | 08:24 AM
06RAMCTD's Avatar
I've not noticed any oil useage with my '06 at all.
The level has always stayed right at the full mark and has never dropped. It does get black as coal really quick after an oil change but from what I'm told this is normal with diesels.
Old 08-27-2006 | 05:34 PM
rockcrawler304's Avatar
X2
Don't seem to be "using" any oil. Still at the full mark wher I put it when I did my oil change.
Old 08-27-2006 | 07:10 PM
CTDinMT's Avatar
45k on mine so far, and its never used oil.
Old 08-27-2006 | 08:26 PM
Donut Gestapo's Avatar
Smile
Can't tell if any is lost on mine either.
Old 08-28-2006 | 06:33 PM
XLR8R's Avatar
HA!
I got all you guys beat... my triple-stacked fueling box CTD actually MAKES oil, usually over a quart a day - which I just recycle back into the fuel tank (just tee the blowby tube into the tank vent )
I wonder if I should get a fuel pressure gauge, though - sounds like those twin lift pumps are workin' overtime!
All that stuff burns inside the cylinders, and it all smells pretty much the same - so why waste it?
How long do you think I should wait before adding any fresh oil?
I've only got about 25K miles on the new engine...
RattlerSkin
20
04-08-2007 11:48 AM
Mike T.
12-20-2006 06:30 PM
tfarmer96
03-23-2005 11:06 AM
JohnnyH
11-15-2004 09:21 AM
MR. GADGET
04-24-2003 02:51 PM
Quick Reply: "normal" oil usage?
