Normal engine operating temperature
What is everybody's engine temp running ? Mine is running around 198-200 deg. at or about 70 mph, unloaded. On I-95 in South Florida, flat road, outside air temp was 84 deg. I have seen engine temp go slightly above 200 deg. in heavy, stop and go traffic with outside air temp at or around 93 deg. Am I running too hot ?
Chip
Chip
I have the Outlook hook up to mine , it read 201 to 203 , going to 207 on a hot day with a/c on. hot=100 degree day
on the dash that equal one needle width before 200 is 201 to one needle width past equals to 207 .
It is Bully Dog digital gauges , I have it set up to read my pyro , coolant temp , rail fuel pressure , and boost press. , I also run the downloader program. I should have called it the Outlook monitor
05 CTD2500
11-27-2009 08:22 PM
squirtdog
08-28-2007 11:30 AM
Pickle
02-13-2004 10:44 AM
