No start- code p0341
My 05 will crank over but not start. I checked for codes, and it gives a P0341.
Does this mean my camshaft sensor is dead? I moved from a Powerstroke because it kept eating these.
unless it is accompanied by a injector code then I would try the crank sensor, if there is other DTC's then it is probably something else
don't worry your CTD wont go through CPS like your Ford did
you might want to just unplug the battery's for a while and see if it clears it.....worth a shot
coope3
12-15-2008 02:39 PM
Steve V.
11-30-2008 03:10 AM
