No BS - MPG figures out of 03-04
Old 12-31-2006 | 06:53 PM
Pop-Pop's Avatar
My stock '04 gets a mixed average of 19 - 21MPG. Easy highway driving (55 - 65) results in 23 - 24MPG. All in-town driving is a useless number because I may be sitting still more than I'm moving. My RWD truck has a 3.73 rear-end. I keep all tires at 70psi. I recently took a 10,000 mile trip to AK, towing a 25 ft. trailer and it averaged 12 MPG (hand calculated & by the overhead).
Old 12-31-2006 | 11:29 PM
C Schomer's Avatar
I've had this truck for 13 months. Last winter, weekend errands and daily commuting I was getting 21.0 average. It went down to 18.5 in the summer with constant AC use. It has only come back to 19.5 this winter - I think it's the fuel. I haven't had the Predator long enough to tell for sure but I think mpg is a little better than 19.5 on the economy tune. I drive easy on the throttle! Craig
Old 01-01-2007 | 12:19 AM
Tony T.'s Avatar
Talking Mileage
I'm seeing 16 to 17 mpg mixed driving, well I call it mixed I guess, since I bought the truck new the state has added four extra new signal lights on the stretch of road I take to and from work. At times it seems like city driving if you catch the lights wrong. Highway miles the last two I hand calculated 19.3mpg on one trip and 20.0 mpg the other trip.
Tony
Old 01-01-2007 | 12:29 AM
streetsmoker's Avatar
Unloaded,and driving like a sane person, and not some speed/power freek I have had many more tankfulls over 20mpg, than under. But with 500+hp underfoot, it's hard to resist the temtation to use it!!!!
I had a thread that cronicled my feet of trying to make 900mi. to a tankfull of fuel. https://www.dieseltruckresource.com/...800+miles+tank
Old 01-01-2007 | 01:47 AM
ramtd02's Avatar
I know i have an '06, but just too show the variations here goes.
I only hand calc. every so often but i can tell you i normally get 700-800 miles on a tank. This is totally stock, driving between 60-65 mph, and 20% city driving.
Just put on the DR.P Predator and after 400 miles i am still in between the 3/4 and 5/8, closer too the 3/4.
Best tank ever got me 889.6 miles and 39.63 gallons = 22.4 mpg (60-65 and did have 10 mph tail wind!!)
Old 01-01-2007 | 08:27 AM
trlman's Avatar
hey ramtd02 mine is same trk also running dr.p along with bdtd with auto trans getting 20.7 hwy. also have smarty on order gona give it a try . lets compare notes once smartys are installed. just noticed,mines dual wheel but should still be interesting comparison!
Old 01-01-2007 | 11:26 AM
gsbrockman's Avatar
My last tank stats :
550.8 miles / 30.168 gals of ULSD winter blend (15 ppm) netted me a hand calculated 18.257 mpg......mostly rural driving (doubtful if more than 140 miles or so on this tank was sane interstate driving). The average mph (14:36 on the trip clock) was 37.726 mph. Mods are in my sig; 305/555 with 3.73:1 ratio and NV5600 six speed; Juice w/Attitude on #2, some idling for warm-up (not hardly cold enough for block heater use yet). Typically I can get low 20's (20.0, 20.1, 20.2, 20.3) on the interstate if I stay near 73-74 mph. My pinion factor has been adjusted so no compensation for the larger tire size is needed on my end.
Greg
Old 01-01-2007 | 07:27 PM
Stealth Mode's Avatar
ok no BS....
city on econ mode...18 to 19.5
highway econ mode highest 28.6 at 67mph running around 1750rpm
ok running only a TST box here and 6 speed 4:10 ratio 37's now about a 3:73 ratio
on standard mode....at WOT level 9 is...............6.5mpg!!!!! untill you let off the pedal.........then back to 17 or so....HP =MPG'S...HP WITH RIGHT FOOT = little to none
Old 01-01-2007 | 09:52 PM
buzzard1's Avatar
My 03 3500 QC Dually auto with .373 gears runs 15 +- 1mpg city and 17.5 at 75mph or 19 at 62-65 mph unloaded. (completely stock)
Old 01-01-2007 | 09:53 PM
J&L's Avatar
J&L
Rhino
weight of the truck and the options added can make a big difference in mpgs. Options such as 4.10 gears/auto tranny/QC/4X4/3500 DRW/big tires/heavy brush guards/etc will drag down mpgs on any truck, even with the Cummins.
I have a 600 mile a week commute, all highway miles, week after week ,month after month so I know what my average mpgs are. The truck has 60k+ and will average 22+ mpgs on that long commute. Towing my 11200 lb 5er on our last 3500 mile trip through NM/TX/UT/WY/MT/CO and lots of 10000' passes averaged 12+ mpgs for the trip. These are averages and not just best tanks. All pencil figures.
This 305/555 HO 3.73 NV5600 has given some good best tanks on long trips. One tank was 23.7 with a next tank back up of 23.2 mpgs. My previous Dodge/Cummins was a '01 2500 auto 3.54 2wd 235/460 engine and averaged 20.5 on the same 600 mile a week commute for the 75k that I put on the truck.
For comparasion, my neighbor has a '05 610 engine 2500 4x4 auto 3.73 with a 800 mile a week and she says her average is 20-20.5 on her long commute. We don't have a city out here so I don't know what mpgs would be for city milage.
JIM
Old 01-02-2007 | 05:26 AM
kry226's Avatar
I've got the early '04 HO w/ 48RE (all stock), 4.10 gears, KORE Pace and 315 BFG ATs:
14-16 mpg city (depending on if I'm running A/C or not)
17-19 hwy mpg (70-75 mph)
18-20 rural hwy (55-65 mph)
I think that's just awesome on a 7,000 lb truck with big tires and auto tranny. Good luck.
Old 01-02-2007 | 09:18 AM
njmaier's Avatar
I've got a 03 6-speed...mods in signature.
I get ~22-23 MPG with the mods below...that's cruising on the highway at 75 MPH unloaded. Around town I get around 17-18 being easy on the go pedal. I always hand-calculate since the computer tells me I am getting 26 MPG on the highway...I wish.
Old 01-02-2007 | 09:37 AM
JHeiser's Avatar
Just did a trip of 2380 miles:
17-18 MPG around town.
19 - 22 MPG highway at 75 to 80 mph
Overall complete trip I averaged 21.35 MPG
All hand calculated. Look at sig for mods.
Old 01-02-2007 | 11:03 AM
sweetwaterguy's Avatar
On my last tank (winter fuel), mixed driving including towing my snowmobiles 80 miles, my hand calculated mileage was 17.6. This is lower than I am used to. Last year I did 2400 miles in all kinds of driving conditions to Las Vegas and on to southern Arizona. My overall hand calculated mpg's were 20.4. I kept rpm's at 2050 on interstate and 1900 on two lane roads.
Old 01-02-2007 | 11:40 AM
robert chilton's Avatar
I know that you are looking for 555 info but I thought that I would throw out my 600 numbers for ya. She gets 18.5-19.5 on the interstate now since I wacked the muffler off (left the kitty). In town is mid 15s in stop in go 15 miles each way never making it more than 3 stop lights. My old 12V gets alot better intown MPG and slightly better on the interstate. I get mad when the MPG is under 16.5 in the city and start looking for problems. These are figures using winter fuel.
Quick Reply: No BS - MPG figures out of 03-04
