No. 6 Injector Bad
No. 6 Injector Bad
Just got the call from the dealership. The Number 6 injector is bad. Is there a known cause for injectors going bad such as Bad Pumps or anything else that I can have the dealership look at before going to pick up the truck?
Joe
Joe
On the first couple injectors on my 04.5 I had rough idle / excessive smoke and poor fuel economy...the last injector to go out pretty much showed me how it was....it filled the crankcase full of fuel and sprayed diesel fuel all underneath the truck (from the crankcase breather tube) all the way to the tailgate.
ok, so:
*bad MPG
*Rough idle
*white smoke
*spraying engine compartment
I get white smoke at start-up a little, but I also have a straight pipe, as far as MPG, SUCKS and the bad idle, meaning like the cab starts shaking a little ?? I dont think I have bad idle tho
*bad MPG
*Rough idle
*white smoke
Mine never ran rough it just seemed to lose a bit of power and sounded like it was detonating at the same time. I also checked my oil level prior to taking the truck to the dealership for A/C problems and found my oil level had risen 1/4 inch.
Joe
Joe
Joe
Joe
Sometimes the injectors just don't work right, remember they are electronic
piesquared
06-10-2009 04:07 PM
