No 4th gear and code p1740
Old 04-25-2011 | 06:12 PM
goran_volvo's Avatar
I was on freeway pulling an empty trailer and hose of transmission cooler come off so when transmission started popping out off gear I pulled over but by that time I lost my oil
So I hooked the hose filed it with oil and drove it home , replaced filter and oil three times and adjusted bands there was a lot black stuff in the oil pan , it was shifting ok for two days now transmission wont shift in 4th gear
at light throttle between 1-2 gear it shifts weird...feels like popping out of gear and then it catches if i floor it every thing is fine
Any suggestions?
Old 04-25-2011 | 06:24 PM
cbrahs's Avatar
sounds like overdrive is smoked. you can bandaide it by doing an overdrive overhaul (new clutches) but that is and will be only temporary.
HerbW
02-04-2015 09:36 PM
CTD600
07-19-2007 12:03 PM
LFD2037
09-13-2006 05:06 PM
DirtEater
05-14-2006 04:33 PM
Turbo Deeezle
06-04-2005 10:18 PM
Quick Reply: No 4th gear and code p1740
