Newbie Questions
Newbie Questions
Just purchased a new to me 2007 Ram SLT 5.9 Diesel. Have been lurking and reading all I can to get up to speed. The truck has already convinced me that I have never really owned a ''TRUCK''. I made the purchase so the wife and I can now upgrade to any size camper that we choose. The truck has 82000 miles and seems to have been cared for very well. I am a clean freak to some degree and have spent 3 days polishing on an already clean truck...lol. I will be putting an exhaust on soon due to muffler has a hole rusted in it and the tip of the tailpipe is corroded. Is this normal lifespan of a stock exhaust? I have always towed with 5.3 Chevy gas trucks which I ran in 3rd gear on a 4 speed automatic. My question is living in hilly eastern Ky what will I expect the transmission to do? Will it take care of itself, ''I assume'' by just putting it in drive and heading off? Thanks ahead and I would expect more questions to follow.
2007 Ram SLT 2500, Cummins Diesel Quad cab 4X4 all stock
I run around with OD OFF as a normal course of daily driving. I like the shift points better.
I am going to guess that you live in a state that salts the roads in winter? The rusted muffler seems to be premature.
A truck as you describe may quite literally just have the engine broken in fully about 15,000 miles ago. The tranny is the weak point for you. It doesn't mean it is a bad tranny, it isn't. It just wasn't made to hold the potential of the engine and the TC will start to slip at some point when it is locked up, you have a heavy load and power up a hill. Being stock, that really shouldn't happen though.
It is too simplistic to say put it in drive and take off. It is best to never lug a diesel. There may be times when 3rd gear is more appropriate even when the engine can pull the load. This is best observed with a good EGT gauge.
EGT, Tranny Temp, Fuel Pressure and Boost are the most common for diesel trucks. You could go crazy with gauges.
Yes, EGT = Exhaust Gas Temperature
Check out Diesel Manor or Geno's Garage.
If you don't have the owner's manual, one can be downloaded for free at this link.
http://www.dodge.com/webselfservice/dodge/index.jsp
Good luck with the new truck!
Oh well, to the original poster- yes, congrats on the truck! And use tow haul mode.
Once you're done cleaning it, you might want to go through and replace all the fluids and filters and adjust the transmission bands, unless you have maintenance records that show all of that has been done recently. You'll want to establish that baseline and then maintain it by the book.
soundbrz
11-07-2002 10:38 AM
