newbie, fuel inj leaking?
new to the board, got 03 quad 4x4 6sp with 147k on it. the last (#6?) inj next to the firewall is dripping fuel. was wondering if this could just be tightened up or is this an O-ring issue. look forward to any and all info, and what a great board. TIA more
it could be anything the whole fuel system is on that side of the engine.
so it could be...
fuel filter
lift pump
return lines
supply lines
hard injector lines
you need to climb under the hood with a flash light and take a good look.
good luck
53
The 03 - 04 sixth injector line has been documented to leak. That is a member,
had the problem of a cracked injector feed line. From 2004.5 and up mother mopar mounted a clamp on that line that attaches to the block lifting lug. It has been one of the nagging issues I should deal with. Go to a Cummins outlet and buy a new injector line and holdown clamp assembly. Or you could waste your time and patience and try the dealer
Fuel leak
Just saw the thread and figured i'd give my two cents since i turned wrenches on Diesels for awhile. If i was you, i'd go get a cheap telescoping mechanics mirror from any auto parts store and with a flashlight you should be able to see exactly where it's leaking from. Eliminates all guesswork. Good Luck!
csrosenberry
06-13-2009 11:47 AM
9 sec camaro
20
08-26-2006 01:30 PM
serious
08-16-2006 10:58 PM
