New Oil Pan Drain Valve Leaks!
You sure that it's not leaking around the washer and dripping down? I noticed that the washer is pretty black also?
I can't believe that the thing is leaking.....there are thousands of people in the diesel forums and on Bob is the Oil Guy that own Fumoto's and I've never heard of anyone having problems with their Fumoto.
Check to make sure that the Fumoto isn't loose and that the oil is leaking down from the gasket. Hope you get it figured out.
Jeff in TD
08-24-2015 08:09 AM
dieselox
04-17-2011 07:24 PM
