New front driveshaft tomorrow
My dealer is replacing my front shaft tomorrow to fix the vibration problem. We took the front shaft out last week and the vibes went away, Hope this fixes the problem. 62 and up Vibration.
Don't know if they use the same front driveshaft between 2nd and 3rd gens, but I had mine replaced 2 weeks ago at 67,000 miles along 2 bad U-joints. Rumble is gone. $600, but I had the $100 deductable drivetrain warranty.
i posted this about a week ago on how to have it fixed front drive shaft baby...
also some people are having the vibration fixed by having something on the front of the trucks changed. :/
Sorry if this is a kinda dumb question, but . . .
I'm going on a road trip this weekend and it would be a perfect opportunity to try my truck without the front drive shaft to see if it gets rid of the vibe. How do you remove the front drive shaft? Is there anything else you should do once you get it off?
Thanks,
Neil
Thanks,
Neil
On the 02's it's 2 bolts on each u-joint (front and rear), and it drops right out. Make sure you mark the yoke position at both ends so it goes back in the same orientation.
Once that's removed. you can collapse the shaft slightly and drop it off the transfer case flange. The four bolts holding the shaft to the differential are Torx-head bolts, either a T-40 or T-45 (can't remember which now). With the back end of the driveshaft removed, you can move the shaft around to allow access to the bolts. Remove these four, and the shaft will pop off.
16mm and T-40.
I did this backwards. The torx bolts are easier to get to without moving the truck, and once the front end is off, you can rotate the shaft freely to get to the bolts on the transfer case flange, as the transfer case is not engaged to the front.
Bowser50
33
07-21-2013 06:33 PM
RonP
02-17-2008 07:54 AM
jaconst
04-02-2006 03:02 PM
