new driveshaft
Stealman1
Forget about that junk two piece drive shaft. I installed the one piece aluminum shaft after reading the great reviews from it. You will not be disappointed with this upgrade. It's worth the money trust me and others who have done it would agree. I bought mine from the dealer who happened to be the cheapest around...go figure LOL. It took about 30 minutes to unbolt the two piece and bolt the one piece in. The vibrations are gone and the truck shifts and drives so smooth.
Does the one peice come with junky ujoints? Is there anything tricky about getting the driveshaft out and putting the new one in? Does anyone know of a write up on it? Does anyone have a part# for the correct drive shaft?
Sorry for all the questions.
Thanks for all the help. I just looked under the truck. Looks like the rear of the driveshaft is connected with 4 bolts through a plate. Then the carrier bearing. Both of thoes look easy. The front looks like some sort of slip connection. What is going on there?
I grabed the driveshaft and tried to move it and look and feel for play in the ujoints. I cant feel anything. How does one determine that the joints are bad. This truck has developed a vibration at 50-55mph. I think it is a driveshaft ujoint or the carrier bearing and that is what the dealer said, but I dont see the problem.
Thanks
Thanks
The carrier bearings that are in the rubber housing in these trucks are junk. I had a vibration too and instead putting money into a junk two piece shaft I opted to get the one piece. It depends how much money you want to spend. But I can tell you that if your dealer is going to charge you 700+ for the repair you're better off getting a one piece. It would be cheaper and you can put it in yourself with just a few common tools.
RonP
02-17-2008 07:54 AM
Dave88LX
06-14-2007 09:52 PM
jaconst
04-02-2006 03:02 PM
Chubby
07-05-2004 10:19 AM
