New to Dodge haveing tranny Probs
Old 05-21-2013 | 11:06 PM
Carmine Pace's Avatar
Hello guy i am new to this site. I picked up a dodge 3500 about a month ago. I had no problems with it till this pass sat on my way home from a 200 mile drive towing like 700 pounds. I got a check engine light codes are P1751 and P1753. Now it is shifting out of 1 at about 2400 rpm to 3k and feels like it is going right in to 3rd and dose not down shift when slowing down. I also feel a lost of power.
I have looked on all of the site to see what it can be.
So in the last 2 days i have changed the TTVA and changed the governor pressure solenoid and the Pressure Transducer.
Still having the problem. It just shift as hard out of 1st now but still in the high rpms.
Now what i did notice i have not seen the TTVA move at all when doing the 30s test with the key on new or old so i am going to return the new one for another one. (I also tested it off the shaft and nothin.
Also the shaft that the TTVA sits on do that move easy or should it be kinda hard to move. I am unable to move it with my fingers.
So any help would be great since i need to tow about 9k trailer/car this coming weekend.
Old 05-22-2013 | 07:53 AM
j-fox's Avatar
Speed sensor on the OD case.
Old 05-22-2013 | 02:39 PM
bought a speed sensor today going to install later to see if that is it.
Old 05-22-2013 | 08:46 PM
changed the speed sensor and that did not work. waiting on the new TTVA tomm and try another one
Old 05-23-2013 | 12:18 AM
Spooler's Avatar
Sounds like the governor pressure solenoid and transducer. Common issue.
Old 05-23-2013 | 08:42 AM
truckbouy2's Avatar
From: Frozen Northern Minnesota, Darn Close To Where Perma-Frost Begins...
He changed that, Spool, unless he got a bad one out of the box.
Old 05-23-2013 | 10:41 AM
Yea i have changed the pressure solenoid and transducer. I got another new ttva today going to install it later today and hope that fixes it.
Old 05-24-2013 | 12:25 PM
chrism69's Avatar
I have an 06 with an ATS Trans. I had the same problem. Changed 3 Throttle Valve Motors, Valve body and an ECM spent 3 grand chasing the problem. Gave up and got a code reader from Auto Zone and when ever it happens I just clear the code and it is good for a few thousand miles.
Old 05-27-2013 | 10:43 PM
ok so i adjusted the 2nd gear band and nothing. had to drive it this weekend to the track how it is. It is skipping 3nd gear and dose not like to down shift. I manually shifted it down and worked half the time. The TTVA is still not moving what else can be causing this issue.
Old 05-27-2013 | 11:02 PM
j-fox's Avatar
When you are driving and it is in third what happens when you manually shift to 2nd? Does it have engine braking?
Old 05-27-2013 | 11:06 PM
I dose not have a engine brake that i know of. 90% of the time do nothin but stay in 3rd. Killed me when pulling the trailer and needed it to down shift
Old 06-03-2013 | 07:42 PM
Ok got the problem fixed after all of things i replaced the ecu needed to be hard reset. The tranny place rested it and it shifts great
hammerdowndodge
10-29-2010 12:19 PM
xj_punk
07-19-2005 12:11 PM
7mmrum
10-20-2004 09:16 PM
warden
02-09-2004 11:29 AM
