need help-tranny service w/band adjustment
i plan on doing a fluid/filter change for my tranny comin up here but also want to do the band adjustment and replace the solenoids. from wat i have read i need to buy a governor pressure solenoid and a transducer. i need part numbers for them too so i can order them and also any links or instructions on band adjustment?
i am outta warranty and have already purchased the solenoid and transducer(sensor) from that website posted, just was kinda hoping to find a how to step by step instructions...oh and yes i do have a dodge dealer half mile from my shop
Search band adjustment on this fourm. There is a thread "how to" It would be better to have tranny shop do it. I understand they can be adjusted from the outter part of the tranny.
Dave
Drop the trans pan, change the filter, and refill until it reads full on the stick with the truck running in neutral. Do this every 20k - 25k miles and this will keep the fluid fresh in your trans.
Don't mess with the bands unless you start having shifting issues. If you over adjust them, or don't adjust them properly, than you'll run out of extra adjustment before it's really needed, or you could completely grenade your transmission.
ghstrider87
04-26-2012 06:35 AM
Idaho Guy
12-26-2009 02:18 PM
TX_Diesel
01-23-2009 02:33 PM
Taxidermyman
40
03-17-2008 06:35 PM
