Need Help Identifying 305hp or 325hp on an 04
Is there a way to tell real easy on an 04 if its a 305 or 325hp? Like does one have "Caution Fan" on the Shroud and the other not?
There is a sticker on the drivers side valve cover showing hp. You could also look under the truck and if it has 4" exhaust and a cat it is the 325 hp, unless the exhaust has been changed or modified.The 305 has 3 1/2" and no cat. Hope this helps.
1Coyote
42
06-27-2013 02:33 PM
Townsend600
18
11-08-2006 06:48 PM
