Need a Gut Check on my EGT's
I seem to think my cold start and normal driving EGT's are a little high, so I need someone to verify what theirs does at these same times:
Cold start - 30 sec's: 425, 60 sec's: 475, put in drive and with just slight throttle up to mid 600's. Then it seems to drop as I start accelerating on the road. After its warmed up, cruising on flat interstate at 70 it holds between high 600's and low 700's. (start up temps are with the exhaust brake on, also.)
I've been getting black smoke right on start up (cold start only), and have been trying to isolate the facts..but started second guessing myslef when I started looiking at the EGT's. It doesn't seem like leakdown at this time - no fuel in the oil, no white smoke at all, and no rough idle. Smarty is now on level 3, XZillaraider is off. Air filter has been cleaned. Power does not seem to be up to snuff.......but that could be in my mind also.
Idling egts seem normal with EB on. What's egt at idle, right after start, with EB off? 300+/- ?
Driving egts are so dependent on all other factors (mods, settings, conditions, etc.) it's difficult to make a good comparison. However, your interstate cruising egts seem in the normal range for a stock charger.
Seems normal. Mine runs 600-800 on the flat highway 75mph (nothing is really FLAT around here though). Hits 900-1100 over the passes depending how hard I'm into it. 1300-1400 over the passes with a trailer 60-70mph.
Doesn't seem any lower or higher with Bullydog on stock or performance mode (75hp).
Yeah mine'll hit 1400 deg if I plant my right foot going over a pass with a trailer hooked up. Bullydog does not make it run any cooler, but it overfuels more than some programmers I think. I can black out an intersection with the best of them if I lug it and punch it!
Hmmm Weird... Usually excessive unburned fuel cools the cylinders and exhaust. I don't know what the Smarty does, but it won't get as hot as it used to. I figured it was overfueling to keep temps down. I know with my foot in it the mileage sure falls flat!
the changes in timing is what cools it down?
JThiessen:
I agree with what the other DTR members have already said,.....your numbers look fine to me. Your EGT numbers are pretty well in-line with what I see on my 2006 too.
John_P
Thanks guys - makes me feel a little better that I dont need to worry about the turbo right now. Guess I'll just keep waiting on this black smoke at the start to either get worse, or maybe it's just what this truck is going to do.
The timing doesn't cool anything down it just puts more heat into the cooling system and heat soaks the piston rather than spit it out the exhaust. X amount of fuel still gives Y BTU's, we just can't measure it when it is in the cylinder too long.
Timing, the BullyDog doesn't use as much timing as what a lot of people run the Smarty on, same as the E\JA.
That statement is true for gasoline, but diesel is a different story. If you put in more fuel without more air, you will have higher EGTS. (It may be the same for a gasser, but no one really measures EGTS for gasoline vehicles.) You need more AIR or WATER injection (Effectively creates cooler denser air) to cool EGTS in a diesel.
Increasing the timing will show lower EGTS, but as stated above is because more heat is being kept in the cylinder creating heat soaked parts.
Stoichiometric rich will also drop the temps and power as too much of the combustion heat is trying to heat the excess air.
