Napa U-joints
Old 09-20-2005 | 08:49 PM
n5oxp's Avatar
Napa U-joints
Will the Napa #351 work on both ends of my drive shaft? Note that it is a regular cab 3500 DRW 4x4 with a one-piece shaft.
Old 09-20-2005 | 09:46 PM
B.Law's Avatar
I don't think so, Napa's website shows either the 295 or the 330's for the single piece driveshaft. The 351's are for 2 piece driveshafts with a 6 speed gearbox.
I had a u-joint from my '01 3/4 ton that I compared to the 351's I just installed today, and man the 351's are so much bigger! I remember back in the day I thought the 3/4 ton u-joints were big till I seen these.
Old 09-20-2005 | 11:07 PM
n5oxp's Avatar
Thanks for mentioning the Napa website. I didn't realize they had a vehicle search feature. I noticed they listed the 330 and 295 for both the two-joint and three-joint shafts.
Old 09-21-2005 | 10:00 PM
B.Law's Avatar
Yeah, they had differnt numbers for auto's/manual's and 2/3 piece shafts for some reason. The "super strong" joints are only available the auto's, I have no idea what the actual difference is...
But for the 1 ton two piece driveshaft guys, the Napa 351's work on all three joints.
Old 08-05-2006 | 07:12 PM
Jerry R's Avatar
n50xp,
What joints did you get and where. I lost one on my rear driveshaft and can't find one anywhere. Dodge dosen't even have any in their 3 parts depots. I believe Neapco is the only aftermarket company that makes them but I can't get one from them till next Thursday because they are out of stock
Thanks for any help. And why does standard cab with long bed and 6- speed have to be so different?
Old 08-08-2006 | 03:29 PM
hparfitt's Avatar
I think the NAPA parts numbers might be incorrect. I just replaced mine with #351's. I have a 1 piece shaft and a 6 spd. The bearing cups on the 351's are 1 3/8" the 330's are smaller 1 1/16.
Old 08-08-2006 | 10:51 PM
PourinDiesel's Avatar
With the 351's remember you still have to grind off about 1/16 of each end on the cap so they fit perfectly.
Takes about 5 minutes of work with a bench grinder.
Old 08-09-2006 | 12:41 PM
04.5RAMHD's Avatar
I think I put the 330 joint in mine . The only difference between the 295 and
330 is the location of the zerk fittting. I didn't think there was a difference
between the joints for manual or auto on the 3g trucks, but I learn something new everyday.
Old 08-09-2006 | 01:10 PM
Mcmopar's Avatar
Why on earth would you grind them?
Old 08-09-2006 | 02:26 PM
Because they are dimensionally bigger than the stock dodge u joint.
This has been discussed before. Do a search.
Erwin Herrera
08-16-2010 07:53 PM
zx14on2
08-05-2010 06:48 PM
IAFF 3445
09-19-2008 12:57 PM
Seeder
02-15-2006 08:15 PM
Dynocon
03-05-2005 06:24 PM
Quick Reply: Napa U-joints
