Napa smf Clutch question
Old 02-24-2011 | 07:12 AM
whitebuffalo's Avatar
Ok, I loaded up Sw 3 with the most timing and least torque management (most aggressive) and it held.
Also, I fixed the shifter boot. Noise wise: I can tell zero difference from the stock one, with the only exception being when you lug it. It rattles a little below 1200 Rpms but it's not loud or obnoxious by Any means.
Old 02-24-2011 | 08:07 AM
Danderson's Avatar
The Perfection clutch sounds like it's doing the job. A long term report will be appreciated. Standard Transmission is recommending Pennsoil Synchromesh for these G-56's as they are seeing some burnt internals on their rebuilds.
Old 02-24-2011 | 06:32 PM
I put about 25k a year so I'll keep y'all posted. I run amsoil 1 qt overfilled, fwiw
Old 02-24-2011 | 09:15 PM
rockcrawler304's Avatar
Thanks for the update! That's good to know
Old 02-27-2011 | 09:51 PM
One last little update to this, I spent all weekend moving cattle, the noise is noteworthy at low rpm, especially with a trailer. Not obnoxious, but undoubtedly there. The loudest is when you're just idling in gear (going through the pasture, pulling through gates, etc.) I just thought I'd mention that since I previously said there was very little noise.
Old 02-28-2011 | 11:04 AM
hawkeye759's Avatar
I am looking at this clutch, but have a question about the Foot Note on the Perfection website for this clutch set.
It states "Requires use of Original Equipment Crankshaft-to-Dual Mass Flywheel adaptor."
A little more info from those of you that have installed this clutch set would be great.
Old 02-28-2011 | 05:01 PM
The p n I have listed came with clutch, pressure plate, t o bearing, and flywheel. The whole nine yards.
Old 02-28-2011 | 05:02 PM
Edit: I think that's referring to the piece the flywheel attaches to.
Old 02-28-2011 | 05:23 PM
OldDodgeOwner's Avatar
I'm pretty sure that's correct.
ted_pulliam
0
07-19-2010 09:00 AM
arvo
03-15-2009 07:39 PM
IAFF 3445
09-19-2008 12:57 PM
cLAYH
06-23-2006 09:00 PM
3500Dooly
06-06-2006 08:36 PM
Quick Reply: Napa smf Clutch question
