NAPA filters
Old 11-26-2008 | 07:18 AM
PZM123's Avatar
NAPA filters
Got a new NAPA store about 5 minutes away. So wondering how they rate with the other filters? [fuel & oil]
Old 11-26-2008 | 07:25 AM
patdaly's Avatar
NAPA sells Wix, so they are good.
Old 11-26-2008 | 07:34 AM
cincydiesel's Avatar
Wix apparently does not have water seperation for the fuel filters. Plus the lowest micron offered is 7.. I've been running their oil filters for years with no problem..
Old 11-26-2008 | 07:43 AM
MikeyB's Avatar
Wix oil filters are ok. But when it comes to fuel stick with either the Fleetguard or Baldwin.
MikeyB
Old 11-26-2008 | 09:34 AM
AH64ID's Avatar
Wix is a water separator, but its best filter for fuel is 7 microns nominal. OE requires 7 microns absolute.
MikeyB
Yep... Baldwin PF7977 is the best OE drop in.
Old 11-26-2008 | 09:43 AM
tcr's Avatar
tcr
Does DC specify 7 mic absolute? WHere is this info if you don't mind?
Old 11-26-2008 | 09:56 AM
silver bullitt's Avatar
I got a great deal on some NAPA fuel filters and had nothing but problems. Truck would buck every now and then and when towing it was very bad. The filters just don't flow very well. (better filtering). This happened with 3 Napa fuel filters. A buddy of mine is a big truck diesel mech. and said those cummins engines are very picking of fuel flow. Ordered a OEM cummins filter problem solved right away. I have 8000 miles on the cummins filter, where I got the bucking issue with the NAPA within 10 miles.
Sean
Old 11-26-2008 | 09:59 AM
surfram's Avatar
I have run Napa-Wix air/oil/fuel filters for years with no problems. I have 87,500 miles on my truck. I order in bulk from fleetfilter.com.
air filter- 2846
fuel filter- 3585XE(7 microns), the older 3585 is 10 microns
oil filter- 7620XE(high efficiency version of 7620)
Can you tell if this fuel filter is Napa-Wix or Fleetguard?
This oil filter?
Old 11-26-2008 | 10:13 AM
AH64ID's Avatar
http://dodgeram.info/tsb/2006/14-007-06.htm
Old 11-26-2008 | 10:14 AM
AH64ID's Avatar
You can run what you want.. .but the WIX fuel filter is not up to par.
Old 11-26-2008 | 10:35 AM
DUKCALN's Avatar
Wix 7620xe, is it a 1/16 thread and will it work on the amsoil by pass system. Want to use it as the oil filter in the system
Old 11-26-2008 | 10:42 AM
AH64ID's Avatar
It is a full flow filter...
Old 11-26-2008 | 10:45 AM
DUKCALN's Avatar
I know it is, so is the amsoil oil filter on the sysytem, I will still use the amsoil by pass filter but want to use the wix filter in place of the amsiol oil filter
Old 11-26-2008 | 10:55 AM
AH64ID's Avatar
Why? The Wix is 14 microns nominal, the Amsoil is 15 microns absolute.
Old 11-26-2008 | 10:57 AM
surfram's Avatar
The 7620XE is the standard 1/16 thread:
Part Number: 57620XE
UPC Number: 765809526204
Principal Application: Extra Efficiency Version Of 57620 - Has Fluted Can (can use in place of 51607)
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper/Glass
Height: 7.000
Outer Diameter Top: 3.690
Outer Diameter Bottom: Closed
Thread Size: 1-16
By-Pass Valve Setting-PSI: None
Beta Ratio: 2/20=14/25
Burst Pressure-PSI: 378
Max Flow Rate: 12-15 GPM
Nominal Micron Rating: 14
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.830 2.440 0.225
Quick Reply: NAPA filters
