Mystery oil leak solved. Thanks guys
I responded to a thread about rear main seal leaks on 2006. Someone later mentioned loose clamps on coolant line on rh side of engine above turbo. Checked today after seeing taletale spot on driveway & bingo clamps were fingertight. Everyone should check this as it would ruin your day if hose slipped off while blasting down the interstate.
Same thing happened to a week after I got truck except it got hot and spewed all the coolant out of the truck that was fun here comes the tow truck............ By the way my stupid dealer wouldnt warranty it unless I had it their so it had to be towed.......... Better than having to buy the hose and coolant I guess..........
Topper
07-09-2009 02:50 AM
