My truck is a big pile of crap
Old 12-07-2007 | 10:58 PM
na4now's Avatar
My 98.5 will run circles around my 2004. And its got the original vp44 w/ 190K miles.
Old 12-07-2007 | 11:15 PM
RAMRODD's Avatar
Take your truck back to the tire store and tell them how your truck is driving with the new tires. This happened to me once but I was back to the tire store after 10-15 miles. The rear of my truck was all over the place. I was surprised when the manager said I wasn't the first guy this has happened to. I picked out a different tire, they put them on and all was well.
I have no Idea why the other tires acted the way they did.
Old 12-07-2007 | 11:32 PM
82NDSNPR's Avatar
called gap insurance and a real good friend to do the dirty work.....you can figure out what that work is.....
Old 12-08-2007 | 04:42 AM
trik396's Avatar
I can't see how you can complain about your truck that much... I mean to call it a pile of crap? My 05' has been great. No problems, knocking on wood. Course I added an external fuel pump asap. I make great power even with my larger tires. That could be where some of your power has gone. Taller tires that weigh more eat up horsepower. Don't blame the truck for your decisions.
Old 12-08-2007 | 09:12 AM
05HDRAM's Avatar
Did you look at the build date ? Could be you got a slacker hour truck. No two trucks are going to be exactly the same. I have been very lucky with just about every vehicle I have owned. I did buy an '82 Dodge Ram-50, and was replacing something on it almost every month. My 2005 has been great since the day I drove it off the lot. My only suggestion is to keep after the dealer until they fix the problem. For your steering problems, it could be a bad tire - out of round or not balanced properly. Don't forget that these trucks come with really crappy shocks, and if you did not change them that is not going to help.
Old 12-08-2007 | 01:06 PM
chipmonk's Avatar
cut the guy some slack why don't you! going through a divorce and having your truck not running right is a miserable combo in my book. i will also say a big thanx to sgt. miller- because of what you do, most of our biggest problems involve the small things like how to get our trucks running right.
Old 12-08-2007 | 06:14 PM
Foxborough's Avatar
I happened to see a diesel service that had a sign about a Dyno. Do a lot of service centers have a dynomometer to service the big rigs? If so what about taking the truck there to see if there is a lack of horsepower. Just a thought.
Old 12-08-2007 | 06:41 PM
Mopar72's Avatar
thanks for all the help guys. I am glad i could serve my country and if i can get my weight back down i am going to go back in to the army.I think i am just going to save my money up and buy a airdog for my truck. I am pretty sure the lift pump is bad again. I can get another one warrented. but i do not want to have to go back to the dealer every other month to have the lift pump replaced.thanks guys Bobby
Old 12-08-2007 | 09:10 PM
Hounddog's Avatar
The in tank pump has had very few issues.Very few.
Old 12-08-2007 | 09:21 PM
Mopar72's Avatar
Question
Hey i am not saying you are wrong or any thing. But i am sure 99.9 percent that the lift pump is bad again on my truck. That will make it the 3 pump on my truck in less than 30,000 miles. I sold my smarty so all i have on it is the Quad XZT now.On a hard pull in sixth gear my lift pump fuel pressure will go to zero. maybe my quad is killing my lift pump. But i do not know why? it is just a little 65 horse box.I know the smarty on wild torque managment sw9 would only pull the fuel down to 3-4 psi.But hopefully i will have a airdog order
monday. thanks Bobby
Old 12-09-2007 | 02:19 AM
realsquash's Avatar
Check the pressure in your tires. I would be willing to bet it's WAY high. Lower to something like 30lbs in the rear and 40 in the front and go up from there. It seems like the tire shops always pump them up to 80psi and let you leave that way. It drives like there are marbles under the wheels with the extra pressure.
Andy
Old 12-09-2007 | 03:37 AM
trik396's Avatar
Ummm.... when I had my stock pump and only Quads XZT it would pull down to zero at WOT every time. That's why I made my fuel system with the Walbro. Nothing wrong with your stock pump except it's stock and you're asking too much from it.
Old 12-09-2007 | 10:39 PM
Timmer's Avatar
Andy
this is what i was thinking, it happened to me. 80 pounds all around. try it and get back to us.
Old 12-09-2007 | 10:59 PM
Mopar72's Avatar
Timmer on my cooper tire post i said that the tire shop only put 50 psi in them. But when i had the blance checked i had them air the tires up to 65 psi. that helped the sway some but not a whole lot. I am going to call the place i got the tires from and see what they can do for me.thanks for the help though. Mopar72
Old 12-10-2007 | 06:36 AM
bluepp's Avatar
You guys with lift pump problems, check your fuel tanks on top for the open elbows setting in the concaves on top of tank. Theres two of them ,one at front and one on rear of tank top. These elbows are open and let all kinds of crud into tank. This crud goes through the lift pump unfiltered . My 1998.5 was like this and my 06 is also. Drive on good roads and no problem, but drive on bad .wet ,nasty roads and crud will get in tank. 18 inches of 1\4 rubber gas line with a cheap inline gas filter pluged on end ,and put this on the exposed elbow, let line hang down between tank and shield beside tank.
dieselfumes57
16
11-07-2008 09:15 AM
Bradtothebone
05-19-2007 11:26 AM
3500Dooly
04-26-2006 11:12 PM
Quick Reply: My truck is a big pile of crap
