My hard starting problem has been fixed!
MY HARD STARTING PROBLEM HAS BEEN FIXED!
Thanks to Topper, I pulled out the Cascade valve and cleaned it, took maybe 15 minutes. I has been 2 days starts better than it has in a long time.
see thread
https://www.dieseltruckresource.com/...d.php?t=177547
see thread
I hope this is finally the answer! I just read that other post again, sounds good hope it fixes you up. When you removed it is the spring and plunger in the pump or does it come out with the COV? And its simple to clean huh ill check it out.
It has a spring and plunger, mine looked fine and moved up and down fine, I spraved it with wd-40 and blew it off 3 times and put it back in, don't tightened very tight.
Starts in about 3 seconds when warm instead of 6 or 8 as before
riddle family
33
02-05-2010 04:01 PM
JTBbudman
05-11-2009 01:03 PM
tony597fitter
12-17-2006 06:30 PM
jwtuc
14
03-22-2004 08:35 PM
