Must be the gauge? this EGT can't be actual?
Old 03-16-2009 | 06:03 PM
davelinde's Avatar
Today I pulled into a parking lot after a short trip (not towing) and saw my X-monitor start throwing EGT alarms. It was reading 2211. After looking at it a little oscillating between 2211 and 2209 I decided the gauge must be wrong and shut down. Driving home it started off at 2211, then "cooled down" to 5-600 while driving. I stopped along the way and reset the connector between the thermocouple and the X-monitor unit and viola - temps are back down to 300's again.
So... I guess this strongly indicates a bad connection and/or failing sender? Right? There's no way I could have EGT's at 2200+ and not have the truck light other idiot lights (if 2200 is even possible?).
Just wanted to be sure I was not assuming the wrong thing. Oh yes, the manifold was not glowing red and the X-monitor is about 5 years old now and always worked great.
Old 03-16-2009 | 07:25 PM
xtoyz17's Avatar
Check the wires and make sure they're not loose, grounding, etc...
Shawn
Old 03-16-2009 | 09:44 PM
madhat's Avatar
Administrator/Jarhead
It's a ground. Undo and re do the connections, make sure that they are not corroded. Some sandpaper or a small wire brush will take care of it.
Could be the monitor itself, but usually it's the ground.
Old 03-17-2009 | 09:30 AM
davidj54's Avatar
Most temperature units are designed with burn out protection. When the sensor or wiring breaks or has a high resistance, the unit reads high. They do this so that if you have a sensor fail it shuts the unit down instead of letting you believe everything's ok.
Old 03-21-2009 | 08:39 PM
davelinde's Avatar
The temps have been normal ever since I reseated the connect to the thermocouple. As you all mentioned that was my guess too and looked like the problem. I just wanted to be sure that a symptom like that (eg real temp spikes for no reason) was not related to something real. THANKS.
Old 03-21-2009 | 11:15 PM
madhat's Avatar
Glad you got it fixed.
Totallyrad
07-19-2011 07:41 AM
mr T
04-30-2004 08:56 PM
chuckr72
03-28-2004 11:37 AM
Huntindad
02-06-2004 05:57 PM
misterKTM
03-04-2003 09:23 AM
Quick Reply: Must be the gauge? this EGT can't be actual?
