multiple rearmains ***!
Old 08-16-2010 | 07:03 PM
Secondrate's Avatar
Ok I have had three seals put in. In less than 15000 miles please someone tell me what is going on. Is there something I'm missing. It has 116k I can feel air from the blow by tube at idle and then at 1500rpm it feels the same. I'm lost and am about to sell it yes yes because of a seal. Need input thank you chad
Old 08-17-2010 | 04:06 PM
Secondrate's Avatar
No ideas
Old 08-17-2010 | 05:11 PM
mini14's Avatar
u have a groove in the shaft
Old 08-17-2010 | 08:13 PM
Secondrate's Avatar
So.what do I do about that how do I get it to stop leaking
Old 08-17-2010 | 09:15 PM
rockcrawler304's Avatar
Not sure what it could be but a groove would cause that. After you replace the seal it holds for a while and then starts to leak. The only real way to fix it is pull the crank and have it polished out, unless it is too deep. I did this on a gasser V8 I built for my jeep. It was either try that and pray for no leaks or replace the crank.
Old 08-17-2010 | 10:06 PM
torquefan's Avatar
If the seal area on the crankshaft is scored or undersized, a simple and acceptable repair would be to buy a rear main seal kit that includes a wear sleeve. Press the sleeve onto the crankshaft and install the oversized seal that comes with it. Problem solved.
However, on a 3rd gen truck, I believe there is an o-ring between the rear of the engine block and the adapter plate. Unlike the older engines, the adapter plate is contacted by engine oil, and this o-ring can cause a leak that resembles a rear-main seal leak. I would check this first.
Old 08-18-2010 | 10:03 AM
Secondrate's Avatar
That is a good answer I will look in to that one thank you
Old 08-18-2010 | 09:50 PM
C Schomer's Avatar
Are there any oil galley plugs on the back of the block that could be leaking? Craig
Old 08-19-2010 | 10:12 PM
Secondrate's Avatar
The mechanic is going to use a smoke machine and find the leak so we will see
rip 112
19
06-17-2008 09:38 AM
blueandsilver02
03-11-2004 09:09 PM
Trailer
07-02-2003 11:55 AM
pappyman
12-07-2002 01:06 PM
ROCKNRAM
11-20-2002 05:20 PM
Quick Reply: multiple rearmains ***!
