mounting a dahl fuel filter
someone has to have a dahl 100 on thier truck they are the best protection for bad fuel and filter to 2 mircons even at zero temps flow rate is max 65 gallons per hour with the 2 micron filter just want to get some ideas on where to mount on a dodge
thanks
thanks
I used a Racore and I located it on the back side of the front of the box (in front of the left rear wheel just ahead of and below the filler neck. It filters the fuel from my auxillery tank befor it goes into the factory tank. Racore like Dahl have 2, 10 and 30 micron elements availible and I use a 2 in the summer but I have to go to a 10 in the winter as the fuel does not flow fast enough to keep up to the consumption even with winter fuel. I am just using gravity to transfer the fuel. When we tow in the winter I can acutualy pull fuel from the factory tank faster that it can flow in through the 10 micron element but when you stop for lunch it catches up. the part # for the Raycore elements is 2010.
Jim O
Jim O
motomac3
09-06-2007 10:05 PM
motrapper
05-03-2006 05:37 PM
motrapper
01-17-2006 07:53 PM
motrapper
10-04-2005 12:53 PM
