more crazy stuff
more crazy stuff
Hea guys something to check. I was changin my front & rear diff. fluid and when i pulled the front cover i found that one of the lock bolts that hold that little wire key in was gone!! the wire key that holds the ring gear from movin and the bolt got eatin for lunch by the ring & pinion.
just something else on this 06 . when you change your fluids don`t forget to check the lock bolts.
Loopi
05-11-2007 03:32 AM
