Minor Leak - Oil? PS Fluid? Can't Trace It
I'm trying to trace a very small leak. Sometimes, when I park in my space in my condo development, I find a couple drops of oil (can't tell if it's engine oil, or brake fluid, etc) dripping right from the front passenger side, almost directly behind the bumper. It doesn't do it ALL the time - for instance, at work, where I park in the same space every day, it has been dry.
Went on a little run today, came home, and now there are a couple drops. I can see where it dripped off the front crossmember (??), but I can't see how it accumulated on that. Using a flashlight from above and below, everything looks dry as a bone.
Suggestions on where to look? Thanks.
How about from a connection to, or from the power steering oil cooler?
Thanks.
Top is transmission oil cooler, bottom smaller one is the power steering oil cooler.
The passenger side is the hoses which route to the tranny cooler.
Well, the truck is due to go in for service in about a month, I'll have them check it out.
Scott...are you sure its oil? The water pump is also on the passenger side and it could be weeping. Just a thought. That might account for the occassional drip????
I guess when it goes in for regular service next month, I'll have them replace it.
Oil leak
Took my 2002 3500 to dealer for LOF and noted I had an oil leak. Dealer found the oil breather bottle was full to overflowing, and that was where the oil was comming from. I have had truck about a month, and with only 10K miles on it was supprised the bottle was full.
ROCKHEAD
10-18-2009 03:17 PM
DennisT
11-10-2007 12:04 AM
Foxborough
09-13-2007 10:09 PM
Haulin_in_Dixie
10-04-2004 06:38 PM
